HyperCrash
Weldline
Weldline
Previous topic Next topic Expand/collapse all hidden text
Weldline
/WELDLINE/Nbpoint/id(/title)
Where:
Unit
•WELDLINE
is a keyword
Keyword
No
•Nbpoint
is the number of part or subpart to weld (Integer < 6)
Integer
No
•id
is the identifier number of the spotweld
Integer
No
•title
is the name of the spotweld
String
No
This is the same format as the spotweld. Only the keyword is changed.
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/WELDLINE/2/3
       -678.822        -449.455          301.25
      1       2
UNCREATED
/WELDLINE/3/7
       -670.155        -519.814           299.2
       -670.155        -519.814         299.533
       -670.155        -519.814         300.013
      1       2
CREATED
/NODE/12844
/NODE/12843
/NODE/12845
/SPRING/7
/SPRING/9
/INTER/53
/INTER/54
/INTER/55
/SHELL/358
/SH3N/1456
/SHELL/567
Go to
M00 File Description for Main Module
