HyperCrash
Hemming
Hemming
Previous topic Next topic Expand/collapse all hidden text
Hemming
/HEMMING/Nbpoint/id(/title)
Where:
Unit
•HEMMING
is a keyword
Keyword
No
•Nbpoint
is the number of part or subpart of the hemming (Integer < 6)
Integer
No
•id
is the identifier number of the hemming
Integer
No
•title
is the name of the hemming - optional
String
No
This is the same format as the spotweld. Only the keyword is changed.
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/HEMMING/2/3
       -678.822        -449.455          301.25
      1       2
UNCREATED
/HEMMING/3/7
       -670.155        -519.814           299.2
       -670.155        -519.814         299.533
       -670.155        -519.814         300.013
      1       2
CREATED
/NODE/12844
/NODE/12843
/NODE/12845
/SPRING/7
/SPRING/9
/INTER/53
/INTER/54
/INTER/55
/SHELL/358
/SH3N/1456
/SHELL/567
Logical Connection
/CONNEC/TYPE/id
Where:
Unit
•CONNECT
is a keyword
Keyword
No
•TYPE
is a keyword which is the type of connection:
•SPOTWELD
•BOLT
•WELDLINE
•HEMMING
Integer
No
•id
is the identifier number of the connection
Integer
No
Card 1:
1
2
3
4
5
6
7
8
9
10
Nb_elem
Where:
Unit
•Nb_elem
is the number of elementary connection of the type defined in the keyword line
Integer
No
Card 2:
1
2
3
4
5
6
7
8
9
10
Elem_1
Elem_2
Elem_10
elem_Nb_elem
Where:
Unit
•Elem_i
is the identifier number of elementary connection.
Integer
No
/CONNEC/SPOTWELD/19
      1
     19
/CONNEC/BOLT/20
      1
     20
/CONNEC/WELDLINE/21
      7
      1       2       3       4       5       6       7
/CONNEC/HEMMING/22
      9
      1       2       3       4       5       6       7       8       9
Go to
M00 File Description for Main Module
