Types of Antenna Patterns
2x2D antenna patterns contain the vertical and the horizontal pattern in the same file. This is often used in commercial file formats of the antenna manufacturers.
The file extensions of the 2x2D antenna patterns are:
Extension | Meaning |
.msi | MSI Planet file format |
.pln | PLANET file format (identical to .msi) |
