2026
Start using Twin Activate with our interactive tutorials.
Tutorials with modeling and simulation strategies for a variety of systems.
Learn about the new features and enhancements in Twin Activate.
New to Twin Activate? Learn the basics here.
Discovery tutorials for building and simulating simple models.
Tutorial Level: Intermediate Learn how to define the behavior of a spring damper model using an OML Custom Block.
Tutorial Level: Intermediate Learn how to generate a 1000 Hz plus 3000 Hz sinusoidal wave with additive noise, apply a Chebyshev Type II filter, compute a Fast Fourier Transform (FFT) and power spectral density, display simulation results in a vector scope, and downsample the output of a buffer.
Tutorial Level: Intermediate Learn how to model and simulate a simple hybrid system that includes discrete signals and continuous linear systems.
Tutorial Level: Intermediate Learn how to generate code from the UI Designer and use it to run a simulation.
Tutorial Level: Intermediate Create a ROM of a dynamic system using romAI.
Tutorials for integrating Twin Activate models with other software products.
Learn about the features and functionality available in Twin Activate.
Explore the Extended Definitions, OML Guides, Block Library, API Guide and Glossary.
You've got questions? We've got answers!
