Run in Batch Mode
The batch mode option is especially useful for process automation, optimization, and other repetitive simulation tasks.
Run in Batch Mode on Windows
Invoke the script: <installation_directory>\Activate_batch.bat, and then enter either Twin Activate model files (.scm files) or OML scripts (.oml files) as input arguments preceded with –f. For example, for an OML script, enter Activate_batch.bat -f name.oml. For a .scm file, enter Activate_batch.bat -f name.scm
Note: If the model file contains graphical windows, such as plot windows for Scope blocks, the windows are not generated or displayed.
Run in Batch Mode on Linux
Invoke the script: <installation_directory>/scripts/Activate_batch, and then enter either Twin Activate model files (.scm files) or OML scripts (.oml files) as input arguments preceded with –f. For example, for an OML script, enter Activate_batch -f name.oml. For a .scm file, enter Activate_batch -f name.scm
Batch Mode Start Options
Option Argument Required or Optional Description Platform Support
-i <space separated inputs> Optional Passes input(s) to scripts. These options can be accessed in Twin Activate by the OML commands: getcmdinput and getnumofcmdinputs. To pass cell arrays or matrices on Linux, the open/close braces and semi-colons need to be quoted.
Linux example:
-i '{ ' 1,2,3 '}
' [' 4 '; ' 5 '] '
stringA
Windows example:
-i {1,2,3} [4;5]
stringA
All supported platforms.
-f <filename>.<extension> Required
  • Runs a model or a script specified by the file.
  • Requires absolute file paths as the argument (separated by ',').
