Left Matrix Division
Left Matrix Division (A\B) is defined as solving the equation Ax = B.
Depending on whether A is square, under determined, or over determined, the way to solve
        this solution is different. When A is square, x = inv(A)*b. If A is over
        determined, the least squares solution is produced. If A is under determined, the least
        squares solution with the minimum norm is produced.
| \ | Scalar | Row Vector | Column Vector | Matrix |
| Scalar | Divides the second scalar by the first scalar. | x = A\B solves Ax = B using left matrix division. | x = A\B solves Ax = B using left matrix division. | x = A\B solves Ax = B using left matrix division. |
| Row Vector | x = A\B solves Ax = B using left matrix division. | x = A\B solves Ax = B using left matrix division. | ||
| Column Vector | x = A\B solves Ax = B using left matrix division. | x = A\B solves Ax = B using left matrix division. | ||
| Matrix | x = A\B solves Ax = B using left matrix division. | x = A\B solves Ax = B using left matrix division. |
Examples
4 \ 6
ans = 1.5
[5 4 3] \ [4 6 3]
ans = [0.4 0.6 0.3; 0.32 0.48 0.24; 0.24 0.36 0.18]
[4 2 9; 3 7 4] \ [6; 8]
ans = [Matrix] 3 x 1
0.30303
0.81212
0.35152
      Invalid examples:
    [4 2 9; 3 7 4] \ [9 3]
[5 8 3] \ [8; 6; 2]Comments
Currently, sparse matrices are only supported for an operation on the left-hand side with a full matrix numerator.
