Change the Default Units
In Inspire Studio, the default unit of measurement is centimeters. You can also choose from millimeters, meters, inches, and feet.
Tip: When
unit conversion is required, include the units when entering the value. Use standard
unit abbreviations without a space. For example, to enter a value of 1 inch, type
1 in.
- On the Help menu, click the Preferences button.
- In the Preferences window, click Inspire Studio > Units.
You have the following options:
Preference Description Length Define the units used for length. Mass Define the units used for mass. Area Define the units used for area. Volume Define the units used for volume. Density Define the units used for density. Moment of Inertia Define the units used for moment of inertia. Curvature Define the units used for curvature. Save as Defaults Click the Save as Defaults button to save the values entered in the tolerance fields as your standard default settings.
Note: The grid settings update automatically. For example, if Grid #2 spacing has been
set to 1 cm, when you switch from centimeters to inches, Grid #2 spacing will
automatically update to 1 in.
