Cut, Copy, and Paste
Cut, copy, and paste objects using standard keyboard shortcuts, the context menu, or the Edit menu.
You need to select the objects before you can cut or copy them. You can also perform
any of these functions using the right-click menu.
| To | Do this | Note |
| Cut |
| Copy |
| Copy with History |
Copy the selected objects with their construction history. |
| Paste |
The Move tool is opened automatically so you can move the copied object. |
