Python Template
def handle(req):
return {
"status_code": 200,
"body": req.body.decode('utf-8')
This code echoes back your request body message with a 200 status code. Probably not very handy but a good starting point.
Apart from your Python skills, to create a Serverless function you just need to understand how to extract the request information and how to return data.
Request Object
req
) is the only parameter passed to your
handle
function and is an instance of the
Event
class. It has five properties:method
: A string (str
) that contains the HTTP method of the request. Its value can bePOST
,GET
,PUT
,PATCH
orDELETE
.body
: Abytes
object containing the body of the request. If this is plain text, you may want to convert it to a string usingreq.body.decode('utf-8')
to make it easier to work with.headers
: This is awerkzeug.EnvironHeaders
object that contains all the request headers. Read the documentation of this type of objects to know how to use it.query
: Awerkzeug.ImmutableMultiDict
object that contains the query parameters you sent in the URL. This is a special kind of dictionary with extended capabilities that makes it convenient for working with query parameters.path
: A string (str
) object containing the URL path used to invoke your function. Note that this will be just the path that you append after the /invoke
or /async
-invoke
endpoint.
Response Object
handle
function
that will be used to build the HTTP response for your request. This dictionary can
have the following keys:status_code
: An integer (int
) representing the status code of the response. It must be a valid status code greater than or equal to 200. Defaults to200
.headers
: A dictionary (dict
) containing the headers to return.body
: The body of the response. If aContent
-Type
header has not been explicitly set, it will be automatically determined by the body type:- If the body is a
dict
, theContent
-Type
will be set toapplication
/json
. - Otherwise, the body will be the string representation of the value
and the content type will be set to
plain
/text
- If the body is a
None of these values is required. In fact, you can omit the return
statement to send a 200
empty response.
Libraries
SWX Package
- Get an access token.
Secrets
- def get(secret_name: str) -> str
- Returns the value of the given secret. If the secret is not found, an empty string will be returned.
- def exists(secret_name: str) -> bool
- Returns a boolean value indicating if the given secret is found.
import function.secrets as secrets
def handle(req):
if secrets.exists("my_password"):
my_secret = secrets.get("my_password")
Logging
stderr
will be saved as a log entry. You can
simply
use:import sys
sys.stderr.write("My log entry!\n")
logging
package. Make sure to
set the logging level
correctly.import logging
log = logging.getLogger("my_logger")
log.setLevel(logging.INFO)
log.error("ERROR")
log.info("INFO")
log.debug("DEBUG") # This line wont' be logged because Logging Level is INFO
Examples
Here are some simple examples to illustrate how you can write your own functions using Python.
- Adder
- This is a really simple function that gets a comma-separated list of
numbers in the request body and return the sum of them (or an error if
the input format is
invalid).
def handle(req): # Gets function input body = req.body.decode("utf-8") # Parses input as a comma-separated list of numbers numbers = body.split(',') try: # Tries to convert all values to numbers numbers = [float(i) for i in numbers] response_msg = sum(numbers) status_code = 200 except Exception: # Throws an error if something is not a number response_msg = "Invalid input format!" status_code = 400 return { "status_code": status_code, "body": response_msg, }
- MQTT Publishers
- The following example shows how to set up an MQTT client to publish the
payload of the request to the functions/Python
topic.
import paho.mqtt.client as mqtt MQTT_BROKER = "test.mosquitto.org" MQTT_PORT = 1883 def handle(req): body = req.body.decode('utf-8') client = mqtt.Client() client.connect(MQTT_BROKER, MQTT_PORT) msg_info = client.publish("functions/python", body, qos=0) msg_info.wait_for_publish() return { "status_code": 200, "body": "Message published!" }
- Update a Thing's Property
- The following example shows how to update a Thing's Property using the
swx
package to deal with token request and revocation.
