Utility Belt
The Utility Belt is a web component enabling you to add content to Studio, such as function logs and MQTT inspector, that will persist when navigating through other sections in the platform.
You can access the Utility Belt from the lower left hand menu.
Figure 1. Utility Belt Menu
