Go Template
package function
import (
"io/ioutil"
"net/http"
func Handle(w http.ResponseWriter, r *http.Request) {
var body []byte
if r.body !=nil {
defer r.Body.Close()
body, _= ioutil.ReadAll(r.Body)
w.WriteHeader(http.StatusOK)
w.Write(body)
This code echoes back your request body message with a 200 status code. Probably not very handy but a good starting point.
The Handle
function is an HTTP Handler within which your task must
run. You can use more functions in your code to make your code cleaner, but the
Handle function is the entry point of your serverless function.
http.ResponseWriter
in
the correct order! You can easily find tons of great information on how to use them.
Here are few sources:
Libraries
- resty: A really nice to use and simple HTTP and REST client library for Go.
- eclipse/paho.mqtt.golang: The Eclipse Paho MQTT Go client.
SWX Package
- Get an access token.
Secrets
- func Get(secretName string) string
- Returns the value of the given secret. If the secret is not found, an empty string will be returned.
- func Exists(secretName string) bool
- Returns a boolean value indicating if the given secret is found.
packagefunction
import (
"function/secrets"
"net/http"
if secrets.Exists("my_password") {
mySecret := secrets.Get("my_password")
Logging
stderr
will be saved as a log entry. You can
use the log
package for
that:package function
import (
"log"
"net/http"
log.Println("My log entry!")
Examples
Here are some simple examples to illustrate how you can write your own functions using Go.
- Adder
- This is a really simple function that gets a comma-separated list of
numbers in the request body and return the sum of them (or an error if
the input format is invalid).
package function import ( "fmt" "io/ioutil" "net/http" "strconv" "strings" ) func Handle(w http.ResponseWriter, r *http.Request) { var body []byte var sum float64 = 0 //Gets function input if r.Body != nil { defer r.Body.Close() body, _=ioutil.ReadAll(r.Body) } // Parses input as a comma-separated list of numbers numbers := strings.Split(string(body), ",") //Tries to convert all values to numbers for _, number :=range numbers { number = strings.TrimSpace(number) if value, err :=strconv.ParserFloat(number, 32); err != nil { //Throws an error if something is not a number w.WriteHeader(http.StatusBadRequest) w.Write([]byte("Invalid input format!")) return } else { sum += value } } w.WriterHeader(http.StatusOK) w.Write([]byte(fmt.Sprintf("%f", sum))) }
- MQTT Publisher
- The following example shows how to set up an MQTT client to publish the
payload of the request to the
functions/go
topic. - Update a Thing's Property
- The following example shows how to update a Thing's Property using the
swx
package to deal with token request and revocation.
