Change the Display Mode
Select a display mode for a scene, such as Wireframe, Shaded, MatCap, Zebra, Performance Render, and Quality Render.
                In the view controls, click the Display Mode
 tool.
                You have the following options:
Option Description Show Visible Edges Turn on this option to show you model with edges. Wireframe
The wireframe mode offers the fastest display. Objects are displayed as curve meshes. Shaded
The shaded mode is useful for seeing the shape of objects and how lights illuminate the scene. MatCap
The MatCap mode allows you to apply a "material capture" to an object. The MatCap is a complete material that includes lighting and reflection, to quickly sculpt or render the object. A few default shaders are available; you can find more online.
Zebra
The zebra mode is useful for spotting discontinuities between adjacent surfaces. Select horizontal
 or vertical
                                        stripes.Performance Render
- An interactive, physically-based renderer
 - High-speed rendering
 - Works on all GPUs
Quality Render
- An interactive, ray tracing based renderer
 - Highest quality rendering fully featured with a built-in denoiser
 - Works only with GPUs with hardware ray tracing cores available
Render Options
- Face Isoparms: View your model with isoparm lines.
 - Ground Shadows: View your
                                                model with ground shadows.Tip: If shadows are displayed incorrectly, select Reset Ground Plane to reset shadows to display at the bottom of the detected geometry.
 - Mesh Fading: Dim edges on mesh parts when you zoom out. Turn off to clearly visualize mesh part edges as you zoom out.
 - Statistics: View information about the model such as frames per second and performance.
