Pave
Use the Pave tool to create faces manually on an existing object.
You can also use this tool to:
    - Blend two PolyNURBS surfaces
 - Close holes in PolyNURBS geometry
 - Convert PolyNURBS surfaces to solids
Pave an Optimized Shape
Pave a surface by placing points along the contour of an optimized shape.
                On the PolyNURBS ribbon, select the Pave tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select points, reference points, or edges to define a rectangle. A PolyNURBS surface is automatically created
                To add another face to the PolyNURBS surface, click an open edge on the surface, and then place two more points.
                Note:
- Ctrl-click in space with the Pave tool to use the nearest global
                                plane.
 - Ctrl-click a reference axis or plane reference to select the reference. While the reference is selected, all points you click snap to the axis or plane. Ctrl-click the reference axis or plane again to deselect it.
                                plane.
 - Repeat the process to pave additional surfaces.
