Add/Remove (+/-)
Use the Add(+) and Remove(-) tools to modify an existing PolyNURBS cage by adding or removing blocks. This allows you to quickly build the basic shape of a PolyNURBS object.
Add Blocks to Cage
Use the Add(+) tool to add blocks to the face of an existing PolyNURBS cage.
                On the PolyNURBS ribbon, select the Add Blocks to Cage
                        (+) tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Click the face of an existing cage to add a new block. For PolyNURBS surfaces, click an edge to add a new face.
Tip:
        - Hold the Shift key to toggle between adding and removing blocks.
 - When editing PolyNURBS surfaces, click on a face to extrude all connected faces into a solid. Some polyNURBS surfaces cannot be extruded due to the break angle.
Remove Blocks from Cage
Use the Remove(-) tool to remove blocks from the face of an existing PolyNURBS cage.
                On the PolyNURBS ribbon, select the Remove Blocks from Cage
                        (-) tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Click the face of an existing cage to remove a block. For PolyNURBS surfaces, selecting a face will remove the face.
