The File Open Dialog
The standard File Open dialog allows you to select a source file on your hard drive or network.
Find the file or folder that you want to open.
Double-click the file or folder to open it, or select the file and click Open.
Depending on the data source you select, one of the following can happen:
An explorer in which you can further define the details of the file or data to be imported displays.
You are brought to the Preview window, where you can view, select and/or load tables to use.
Your are brought to the Prepare window, where you can begin performing your data prep operations.
You are brought to the Report Design window, where you can define the fields to use from PDF and report files.
You are brought to the Excel Worksheet Design window, where you can define the fields to use from non-tabular Excel worksheets.
Your are brought to the PDF Table Extractor, where you can define tables from PDF files.
Notes:
You can bypass the File Open dialog and open a data source immediately by dragging the file from Windows Explorer to the Start or Preview window.
CSV is accepted as a valid file type that can be opened by the Excel and Worksheet Design connectors.
