Editing a Summary in Data Prep Studio
You can edit a summary to change its name, select a different filter to apply when building the summary, add or remove key fields, measures or item fields, or edit the properties of key, summary, or item fields.
Editing Summaries via the Edit Summary Dialog
Click the Analyze tab to display the Summary options
Select the summary to edit from the Summary drop-down.
Click the Edit Summary button.
The Edit Summary dialog displays. This dialog will show all of the details you specified when you created the original summary. Using this dialog, you can:
Editing Summaries by Double-Clicking on a Column
In the Summary view, double-clicking on any cell in a key, item, or measure column displays a dialog that will allow you to modify the properties of that column.
Click OK after making your changes to close the dialog and apply the changes to the column.
