Inspire Mold is a modern simulation-driven design environment that lets you test, validate, correct, and optimize the design of
injection-molded components.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may
be drawn. These features will be checked out for the duration of the session.
Select a curved arrow, and then enter an angle in the microdialog.
Select a curved arrow, and then drag the object.
Tip: Grab and release parts by their snap points (end points,
midpoints, center points, etc.) to align them precisely. You can temporarily
disable snapping by holding down the Alt key.
Right-click and mouse through the check mark to exit, or double-right-click.
