Find
Find entities in the model that contain the search string you enter. The search results are not filtered.
- Press F2 to open the Model Browser.
Click to open the Find toolbar.
- Optional:
To control your search, click , and then click one or more of the following
options:
- Match Case
- Whole Names Only
- Use Wildcards
- In the text field, type a search string.
Find Options
Option | Description |
Navigate to the next or previous entity that contains the search string. | |
Find every entity that contains the search string. | |
Access additional options to control the search:
