2026.1
New to Inspire Extrude? Learn the basics here.
Learn the basics of the Inspire Extrude user interface.
Learn how to import geometry and export results.
Discover new features and enhancements in Inspire Extrude.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may be drawn. These features will be checked out for the duration of the session.
The Inspire Extrude workspace includes the ribbon, modeling window, legend, and status bar.
Create, open, save, or revert a model using standard keyboard shortcuts, the Files icon, or the File menu.
Learn how to import CAD, configure the import reader for various file formats, clean up CAD on import, and repair invalid parts.
Use File > Import to import and merge a saved model with the current model.
Export Inspire geometry and simulation results for use in another application.
View a list of supported file formats for import and export.
Open, import, and save files to PTC Windchill™ or Siemens Teamcenter™.
Review techniques for selecting and editing objects.
Change the view in the modeling window using the mouse or view controls.
Translate, rotate, and align parts and other objects using the Move tool and snaps.
The Systems tool is useful for aligning loads to a local coordinate system rather than the global coordinate system. Keep in mind that results are only shown in the global coordinate system.
Record a video or take a snapshot of the screen.
Change the default unit system, create custom units, and measure geometry features.
Use the Model Browser to organize your model, organize analysis and optimization objects, and access objects that aren't currently shown in the modeling window.
Learn about the forms of help and user assistance available from the product.
Modify the workspace display, default keyboard shortcuts, and other settings.
A list of supported operating systems and minimum requirements for hardware and memory.
Learn keyboard shortcuts and mouse controls for common operations.
View a list of glossary terms and definitions.
Get started with Inspire Extrude Metal.
Get started with Inspire Extrude Polymer.
Get started with Inspire Friction Stir Welding.
Get started with Inspire Resin Transfer Molding.
Create 2D sketches, surfaces, and solids.
