Import and Merge Geometry
Import and merge a saved model with the current model.
  1. Select File > Import or press Ctrl+I.
  2. In the Import File dialog, select a file. You can filter by file type and show previous versions of models.
  3. Click Open.
Tip:
  • The imported model is inserted as an assembly under the top-level folder in the Model Browser. To move the imported model within the model hierarchy, drag the folder in the Model Browser.
