Generate a Report for Tool Deflection
Create a Microsoft PowerPoint report for Tool Deflection Analysis.
The report explains the model information, material data, and dimensions of each part all in a few clicks. It captures images for result distribution on the entire model and each part, and X and Y cross sections of each part for all result types.
The input file necessary for report generation is optiResHvtransOut.h3d, which is generated after completion of analysis.
                From the Tool Deflection ribbon, select the Report
                    icon.
                In the Report dialog, enter the following:
- Title - Report title.
 - Author Name - Author name for the report.
 - Overview - Overview information to be published in the report.
 - Result Types - Select the preferred result types by clicking on the respective checkboxes. The selection will capture the images of respective results.
                Click Publish. It starts capturing the required images
                    and generates a Microsoft PowerPoint report automatically.
                The report opens.
Figure 1. Report Dialog for Elasto-Plastic Analysis
Figure 2. Report Dialog for Elastic Analysis
