Add a Remote Service Using HyperXtrude Job Manager
Submit extrusion simulation on local or remote machines.
Creating a Remote Service
Note: You must first enable Use HyperXtrude Job Manager in Preferences > Inspire Extrude Run Options.
  1. Click the Run menu under the Analysis tool.
  2. Click Add Server to add a remote server.
    Dialog to add a new service pops up. This dialog is prepopulated with default data to help in entering the correct paths.
  3. Click Save to add the service.
  4. Click Advanced to access the complete job manager setup.
Editing Service
  1. Right-click on the service, and click Edit.
    Dialog to edit the service will pop up.
  2. Click Save to update the changes.
Deleting Service
Right-click on the service to remove, and click Delete.
