/VEL/ALE (Obsolete)
Engine Keyword With ALE links on grid velocities, given nodes are linked to the given main grid velocities. You can specify direction or a combination of directions.
/VEL/ALE/Keyword3/Iform/Keyword5
M1 , M2
ID1, ..., IDn
Definition
Keyword3 A combination of X, Y, and Z:
X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, . . .
Option Formulation flag (Integer)
= 0 (linear):
W N 1 = W M 1 + ( W M2 − W M 1 ) 1 N + 1
= 1 (maximum):
WN1 = WM1 if |WM1| > |WM2|
WN1 = WM2 if |WM1| < |WM2|
= -1 (minimum):
WN1 = WM1 if |WM1| < |WM2|
WN1 = WM2 if |WM1| > |WM2|
Keyword5 «GRNOD» or «NODES» defines the way of providing secondary nodes
M1 First main node number
M2 Second main node number
IDi Secondary nodes identifiers or node group identifier (depending on Keyword5). 2
  1. This card is obsolete. It is replaced by /ALE/LINK/VEL.
  2. Using Keyword5=«GRNOD» requires a single identifier ID1.
  3. Using formulation Iform=0 requires an ordered node list. Using Iform=0 with Keyword5=«GRNOD» also requires an unsortable node group (/GRNOD/NODENS).
