/DT/NODA/Keyword3/Iflag (Obsolete)
Engine Keyword Activates the nodal time step control method with the option to apply mass scaling to increase a model’s time step.
Δ T sca Δ T min initial_mass_ratio
If Iflag=1, insert the next line
grnd_ID
Definition
Keyword3 Time step control type. 1
CST1
Nodal mass is increased to maintain a constant time step Δ T min . 5 6
Recommend Δ T sca =0.67.
CST2
Nodal mass is increased to maintain the constant time step Δ T min . Improved formulation. 5 6
Iflag Node group flag.
=0 or blank
All nodes use the nodal time step method.
=1
The nodal time step method is only applied to the nodes in node group grnd_ID.
Δ T sca Scale factor on critical nodal time step.
Default = 0.9
Δ T min Minimum time step.
initial_mass_ratio Mass ratio increases at the beginning of the computation is used to increase the minimum time step. This value is entered as a ratio, so a 5% increase in mass is entered as 0.05.
Default = blank or 0
grnd_ID The nodal time step method is only applied to the nodes in this node group, read only if Iflag=1.
  1. For all Keyword3 options, the time step control will be activated when the time step of the node controlling the time step of the simulation becomes less than the defined timestep divided by Δ T sca .
  2. Only one /DT/NODA/Keyword3 option can be used in a simulation.
  3. When using Nodal time step, the computation of each cycle is slightly more expensive but the time step can be higher especially for low quality meshes.
  4. For constant nodal time step options, the time step used at the beginning of the simulation is the maximum of Δ T min or, time step calculated with mass added by initial_mass_ratio. The initial time step will then be maintained during the simulation by adding additional mass, if needed.
    /DT/NODA/Keyword3
    0 Δ T min
    The computation is done with minimum nodal time step of Δ T min value. Mass will be added to maintain this timestep.
    /DT/NODA/Keyword3
    0 Δ T min 0
    /DT/NODA/Keyword3
    0 Δ T min 0.05
    Radioss calculates a nodal time step to give 0% of initial mass increase and uses the maximum value of this calculated time step and defined Δ T min .
  5. The estimated time steps for different percentage of mass increase are printed as a table and a graph in the Starter output file.
  6. /DT/NODA/Keyword3 is compatible with all options of /DT/Eltyp/Keyword3.
