/ALESUB (Obsolete)
Engine Keyword Subcycling on Lagrangian parts.
/ALESUB
Δ T sca dummy
Definition
Δ T sca Scale factor on time step for fluid parts
dummy Dummy real variable (actually not used)
  1. The Δ T sca must be less than or equal to 1.0. A value of 1.0 is recommended.
  2. If Δ T sca is equal to 1.0, the time step of fluid parts is equal to the critical time step of fluid.
