Measure of Performance
The Speed-Up is the ratio of sequential time and the parallel time on processors :
The efficiency is defined as:
The Amdahl’s law for multitasking is used to determine the speed-up:
Where, and are the computation times respectively related to parallel and non-parallel parts. As , write:
The limit value can be obtained when the process number tends to infinite:
Table 1 provides the Speed-Up in function of number of processors and the rate of
parallelization in the program. It can be seen that if the rate of parallelization is less
than 95%, the computation acceleration will not be greater than 20; however, the number of
processors. This means that to obtain a good scalability of a code, at least 99% of the
program must be parallel.
| Process Number Seq / P |
2 | 4 | 8 | 16 | 32 | 64 | 128 | |
| 100% | 2.0 | 4.0 | 8.0 | 16.0 | 32.0 | 64.0 | 128. | |
| 99% | 2.0 | 3.9 | 7.5 | 13.9 | 24.4 | 39.3 | 56.4 | 100. |
| 98% | 2.0 | 3.8 | 7.0 | 12.3 | 19.8 | 28.3 | 36.2 | 50.0 |
| 97% | 1.9 | 3.7 | 6.6 | 11.0 | 16.5 | 22.1 | 26.6 | 33.3 |
| 96% | 1.9 | 3.6 | 6.3 | 10.0 | 14.3 | 18.2 | 21.1 | 25.0 |
| 95% | 1.9 | 3.5 | 5.9 | 9.1 | 12.5 | 15.4 | 17.4 | 20.0 |
| 90% | 1.8 | 3.0 | 4.7 | 6.4 | 7.8 | 8.7 | 9.3 | 10.0 |
| 50% | 1.3 | 1.6 | 1.8 | 1.9 | 1.9 | 2.0 | 2.0 | 2.0 |
