By default, kinematic constraints act on material velocities and accelerations. In
Radioss, you can define a wide variety of such
constraints. For multi-physic and fluid applications, options are:
Fixed and full slip boundary conditions
Imposed velocities (imposed flux at inlet)
Rigid links (temporary adds during restarts)
Rigid bodies to model rigid structures and connections and also to compute
drag and lift forces (fluid impulse on rigid body is stored in time history
database)
Grid constraints act only on grid velocities. Specify:
Fixed and full slip grid conditions
Lagrangian conditions (grid and material velocity are equally set)
ALE links to maintain regular distribution of nodes
Imposed grid velocities (moving inlet and outlet)
If fixed node with /BCS, then it means the grid and material are
fixed. If /ALE/BCS is used, then it is different. First 3 codes
defined grid DOF, the second 3 codes defined if node act like Lagrangian in the
corresponded direction.Figure 1.
If set Grilag=010 000, to just fix grid in Y direction, material
could move in Y direction.
If set Grilag=000 010, it means nodes are like Lagrangian in Y
direction, grid and material are tied on these nodes in Y direction.
If set Grilag=010 010, it means grid and material are tied on
these nodes in Y direction and fixed in Y direction. It is like
Trarot=010 000 in /BCS.Figure 2.
