Artificial Damping for Shock Waves
Quadratic bulk viscosity qa and linear bulk viscosity qb are, by default, set to values relevant for hydrodynamics and high speed impact problems involving shock waves.
For fluid dynamics and acoustics, these coefficients are not required, and most generally set to very small values to override the default.
