/MADYMO
Engine Keyword Activates MADYMO- Radioss coupling.
/MADYMO/Keyword2
lunit tunit munit
Definition
Keyword2
MPP
Activates the MADYMO- Radioss MPP coupling.
lunit Length unit conversion factor, must be 1 meter in Radioss model unit.
tunit Time unit conversion factor, must be 1 second in Radioss model unit.
munit Mass unit conversion factor, must be 1 kg in Radioss model unit.
  1. /MADYMO/MPP requires MADYMO 7.1 or higher installation.
  2. If using Radioss- MADYMO coupling, /MADYMO/MPP must be input into every Engine file (Runname_run#.rad).
  3. Units settings: For example, if Radioss model units are mm, s, or kg, the factors will be 1000, 1, 1, respectively.
  4. MADYMO is a registered trademark of TASS-SAFE.
