Engine Keyword Initialize rotational velocity in the specified
direction X, Y or Z on a node
set.
/INIV/ROT/Keyword3/2
grnd_ID
Definition
| Field |
Contents |
SI Unit
Example |
| Keyword3 |
X,
Y or Z. |
Rotational
velocity. |
grnd_ID |
Node group
(/GRNOD) or node set
(/SET) on which specific initial
velocities are applied. |
- The nodes defined in
the node set grnd_ID have the rotational velocity
