/INIV/AXIS/Keyword3/2
Engine Keyword Initialize rotational velocity about an axis and translational velocity on a node set.
Frame_ID
VXt VYt VZt Vr
grnd_ID
Definition
| Keyword3 | Direction X, Y, and Z of the frame defining the rotation axis. | |
| Frame_ID | Frame
identifier. (Integer) |
| VXt, VYt, VZt | Translational velocity
components in the local frame. (Real) |
| Vr | Rotational velocity
about the axis Keyword3 in the local frame.
(Real) |
| grnd_ID | Node group (/GRNOD) or node set (/SET) on which specific initial velocities are applied. |
- If frame_ID is not zero, the initial velocities are applied with respect to this local frame.
- Once
is expressed in the global system, the
velocities are initialized with respect to:Where,
- Vector defining the rotation axis
- Represents a point on the axis and is set as the origin of the frame.
