2026
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword Initialize rotational velocity about an axis and translational velocity.
Engine Keyword Initialize rotational velocity about an axis and translational velocity on a node set.
Engine Keyword Initialize rotational velocity in the specified direction X, Y or Z.
Engine Keyword Initialize rotational velocity in the specified direction X, Y or Z on a node set.
Engine Keyword Initialize translational velocity in the specified direction X, Y or Z.
Engine Keyword Initialize translational velocity in the specified direction X, Y or Z on a node set.
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, and so on) in a state file (STA-File).
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
