/INIV/AXIS
Engine Keyword Initialize rotational velocity about an axis and translational velocity.
/INIV/AXIS/Keyword3
Frame_ID
VXt VYt VZt Vr
N1N2..., NN
Definition
Keyword3 | Direction X, Y, and Z of the frame defining the rotation axis. | |
Frame_ID | Frame
identifier. (Integer) |
VXt, VYt, VZt, Vr | Translational velocity
components in the local frame and rotational velocity about the
axis. (Real) |
or |
N1N2..., NN | List of nodes. |
- If Frame_ID is not zero, the initial velocities are applied with respect to this local frame.
- Once
is expressed in the global system, the velocities
are initialized with respect to:Where,
- Vector defining the rotation axis
- Represents a point on the axis and is set as the origin of the frame
- For easier input and faster initialization of the velocity, use /INIV/AXIS/Keyword3/1 or /INIV/AXIS/Keyword3/2.
