/IMPL/SHPOFF
Engine Keyword The full projection of QEPH shell element for warped elements will be deactivated to keep consistency between the stiffness matrix and the internal force computations.
/IMPL/SHPOFF
- This option could improve the implicit nonlinear analysis with QEPH warped shell elements, in condition that the rigid rotation of warped elements are kept small enough.
 - In the case of finite rigid rotation with the warped shell element, use /IMPL/SHPON for a more precise result.
