/IMPL/RREF/LIMIT
Engine Keyword Define reference force residual limit values used in stop criteria for implicit nonlinear.
/IMPL/RREF/LIMIT
R_min R_max
- Directly defining the reference force residual limits allows to ensure the precision (with R_max) or to make convergence easier (R_min).
Definition
| R_min | Minimum force residual
value. Default = 0 (Real) |
| R_max | Maximum force residual
value. Default = 0 set to 1.e30 (Real) |
