2026
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword
Engine Keyword Deactivating load (pressure) stiffness matrix.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
Engine Keyword A zero stiffness DOF will be constrained automatically.
Engine Keyword Divergence criterion with successive increasing residual number for nonlinear analysis.
Engine Keyword Describes the implicit dynamics with α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ -HHT method.
Engine Keyword Describes the implicit dynamics with a general Newmark method.
Engine Keyword Rayleigh structure damping with dynamic implicit analysis.
Engine Keyword Geometrical stiffness matrix will not be used for implicit nonlinear calculation.
Engine Keyword Describes the stiffness matrix; due to contact interfaces will be assembled completely.
Engine Keyword Defines including some contact nonlinearities in PCG linear solver.
Engine Keyword Implicit linear analysis will take into account contact interfaces.
Engine Keyword Deactivating line search for nonlinear analysis.
Engine Keyword Line search methods for nonlinear analysis.
Engine Keyword Describes the stiffness of gas in monitored volume type 3 (tire modeling).
Engine Keyword MUMPS solver will automatically switch from in-core memory to out-of-core memory.
Engine Keyword MUMPS solver will use minimum in-core memory.
Engine Keyword The computation will be stopped, if Ncy_max is reached.
Engine Keyword Describes the implicit option for pre-conditioning.
Engine Keyword Different reference force residual computations used for stop criteria on nonlinear analysis with contact.
Engine Keyword Define reference force residual limit values used in stop criteria for implicit nonlinear.
Engine Keyword Deactivation reference residual option and using the previous one in stop criteria for implicit nonlinear analysis.
Engine Keyword The full projection of QEPH shell element for warped elements will be deactivated to keep consistency between the stiffness matrix and the internal force computations.
Engine Keyword The full projection of QEPH shell element for warped elements will be activated for stiffness matrix to keep consistency with the internal force computations.
Engine Keyword Describes the initial stresses that will be imposed gradually.
Engine Keyword Implicit spring-back will be run in this session.
Engine Keyword Describes the linear or nonlinear stiffness choices for nonlinear spring in implicit nonlinear analysis.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, and so on) in a state file (STA-File).
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
/IMPL/PSTIF/OFF
