/IMPL/SBCS/OUTCORE (Obsolete)
Engine Keyword BCS solver will use minimum in-core memory.
/IMPL/SBCS/OUTCORE
  1. Normally, BCS automatically manages the use of in-core and out-of-core memory. This keyword allows you to force BCS of minimum in-core use, in case of a memory problem or reserving part of the memory for other applications.
