RD-HM-T: 1040 Gasket
Tutorial Level: Beginner This tutorial demonstrates how to simulate a rubber gasket in sequential loading.
In this lesson you will learn to:
- Step 1: Load the initial model
- Step 2: Define material
- Step 3: Define property
- Step 4: Create rigid body
- Step 5: Create boundary conditions
- Step 6: Set loading
- Step 7: Create time history output
- Step 8: Create Engine setup
- Step 9: Export solver deck and run model
- Step 10: Check results
Model Description
The load sequence is:
- Translation Transverse (10 mm)
- Translation Longitudinal (5 mm)
- Torsion (20 Degrees)
The model description is:
- UNITS: Length (mm), Time (ms), Mass (kg), Force (kN) and Stress (GPa)
- Simulation time:
Engine [0 – 1.501] in steps of 0.5 ms for each load case
- The outer circumference area is fixed on all degrees of freedom (VX, VY, VZ)
- The center node is fixed on X direction and the X and Y rotation (VX, WX, Wy)
- Gasket dimensions:
- Thickness = 100 mm
- External Diameter = 200 mm
- Internal Diameter = 50 mm
- Hyper-elastic material /MAT/LAW42 (OGDEN) (Rubber)
Prerequisites
To run this simulation, you will need access to a licensed version of Radioss. You will need an internet connection to watch the video tutorials and download the files.
Model Files
Before you begin, copy the file(s) used in this tutorial to your
working directory.
