RD-HM-T: 1060 Three Point Bending Model Setup
Tutorial Level: Intermediate This tutorial demonstrates how to set up a 3-point bending model consisting of a head profile and a closing plate.
This validation test is a common test to determine the bending strength during bending load. The usage of the head profile structures is a common design feature in automotive and aero industry.
In this lesson you will learn to:
  • Step 1: Load the initial model
  • Step 2: Define material
  • Step 3: Define property
  • Step 4: Solid spotweld creation
  • Step 5: Define Failure /FAIL/CONNECT
  • Step 6: Create rigid body
  • Step 7: Create boundary conditions
  • Step 8: Create imposed velocity
  • Step 9: Set contact
  • Step 10: Define time history output
  • Step 11: Create Engine setup
  • Step 12: Export solver deck and run model
  • Step 13: Check results
Model Description
The model set up consists of:
  • Material creation (with strain curve creation) and assignment:
    • Elasto-plastic material /MAT/LAW36 (plastic):
      • [Rho_I] Initial density = 7.85e-09 (ton/mm3)
      • [nu] Poisson’s ratio = 0.29
      • [E] Young’s modulus = 210000 (MPa)
  • UNITS: Length (mm), Time (s), Mass (t)
  • Simulation time: [0 – 7.01E-02]
  • Boundary Conditions: The supports are all fixed. An imposed velocity of 1000.0 mm/s is applied on the impactor.
  • Model size: 370mm x 46.5mm x 159mm
Prerequisites
To run this simulation, you will need access to a licensed version of Radioss. You will need an internet connection to watch the video tutorials and download the files.
Model Files
Before you begin, copy the file(s) used in this tutorial to your working directory.
Tutorial Video
