/DVPREL2 (Obsolete)
Optimization Keyword Relates a design variable to an analysis model property using a relationship defined by a /DEQATN card.
The equation inputs come from the referenced /DESVAR values and the constants defined on the /DTABLE card.
| /DVPREL2/dvp_ID | |||||||||
| title | |||||||||
| prop_typ | prop_ID | prop_fid | EQID | ||||||
| VARTYPE1 | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ID8 | ID9 |
| ID10 | ID11 | ID12 | etc | ||||||
| VARTYPE2 | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ID8 | ID9 |
Definition
| dvp_ID | Identification
number. (Integer > 0) |
| title | Title. (Character, maximum 100 characters) |
| prop_typ | Property type. The
type is specified immediately after the corresponding
/PROP, as: 1
(Integer ≥ 0) |
| prop_ID | Property identifier
. (Integer > 0) |
| prop_fid | Property field
identifier to be related with design variable. Depending on
various property types (prop_typ), the
available options are different. 1 (Integer > 0) |
| EQID | /DEQATN identifier that defines the
response relationship. (Integer > 0 or blank) |
| VARTYPE# | Variable type.
| ID# | Identifier
variables defined in VARTYPE#.. When VARTYPE is DESVAR, or DTABLE, this list of IDs reference entities of the defined VARTYPE. |
- The specific property
field ID's that are related to the design variables are listed based on the
following property types:prop_type = 1 (/PROP/SHELL):
- prop_fid
- 1
- Thickness
prop_type = 2 (/PROP/TRUSS):- prop_fid
- 1
- Area
prop_type = 3 (/PROP/BEAM):- prop_fid
- 1
- Area
- 2
- Iyy
- 3
- Izz
- 4
- Ixx
prop_type = 11 (/PROP/SH_SANDW):- prop_fid
- > 0
- Ply Thickness
- < 0
- Ply Orientation Angle
prop_type = 18 (/PROP/INT_BEAM):- prop_fid
- 1
- First size of the predefined section L1
- 2
- Second size of the predefined section L2
- This card is represented as an optimization design variable in HyperMesh.
