OS-E: 2035 Stress and Strain Responses Based on the Neuber Correction Method
The objective is to reduce the stress concentration at the fillet regions of the model by changing its shape.
Model Files
Model Description
- Objective
- Minimize the change in mass
- Design Variables
- Shape Design Variables
This example has a half symmetric valve, which is modeled using first order tetra elements and has a force applied on it at a specific location. A shape ID is created using HyperMorph and the Shape design variables is created. A static stress response is created with Neuber correction and a mass response defined by an equation to minimize the change in the mass. A design constrain is defined for static-stress response.
