Modal FRF - Plot Response
Plot the response options.
- Response File
 - Information from the result PUNCH file with FRF results.
 - Subcase
 - Select a subcase from the drop-down menu.
 - Result type
 - Select the response type, displacement, velocity, and acceleration.
 - Response ID
 - Select the grid ID of the response from the drop-down menu.
 - Direction component
 - Select the component of the response grid ID from the drop-down menu.
 - Display Options
 - The Display Options dialog allows you to customize the response plot, including scale, weighting, and the plot layout.
 - Load Response
 - Once the result selection options are complete, select Load Response to display the response curve. Additionally, right-click in the plot window to convert between the result types and calculate the derived quantities based on a user-defined frequency range (Acceleration to Displacement, Acceleration to Velocity, and vice versa). See Figure 2.
