Modal FRF - Define Modes
Select the modes.
- Modal Result File
 - Select an *.h3d, *.op2 or *.unv file and click Load. Upon reading the file, other fields on the Define Modes tab are populated.
 - Modal Subcase
 - Select a subcase that has normal modes results.
 - Start and End Frequency
 - Select the frequency range from the normal modes frequencies for the frequency response calculation.
 - Modes
- Animate
 - Click Animate to calculate the normal modes animation of the selected mode.
 - Modal Damping
 - Enter a constant value or click the table icon to select a table of modal damping values.
 - Structural Damping
 - Enter the structural damping coefficient.
 - Apply
 - Click Apply to calculate the frequency response results.
