Altair Binary Format
Export evaluated data of each approach in Altair Binary format (*.abf).
This option saves evaluated data in .abf format, which provides flexibility to perform custom post-processing in HyperGraph. It is a study-level operation, meaning that data from each successfully evaluated approach will be saved. Currently, Summary Table, Linear Effects Table, and Pareto Chart data is supported.
Do one of the following:
- From the Study ribbon, Collaborate tool group, click the
Export tool.
- From the menu bar, click .
The Save As dialog opens. - From the Study ribbon, Collaborate tool group, click the
Export tool.
- In the Save As dialog, select Altair Binary Format (*.abf) for Save as type.
- Navigate to your working directory.
- In the File name field, enter a name.
- Click Save.
