Visualize the scatter history of an Optimization in the Iterations post processing
tab.
From the Post Processing step, click the Iterations
tab.
Using the Channel selector, select the data to plot.
Under Iteration History, select the iteration(s) of the
Optimization.
Note: If you select all the iterations of the optimization problem, the
complete iteration history will be plotted accordingly, potentially
including iterations with a violated constraint.
Under X Axis and Y Axis, select the channels to plot.
Any two channels can be selected for plotting on the x and
y-axis.
Tip: For the Y Axis, multiple channels can be
selected. Display selected data in a single
plot or separate plots by switching the Multiplot option between (single plot) and
(multiple
plots).
