Select a Numerical Method
Select a numerical method to use when evaluating the Fit.
- In the Specifications step, go to the Specifications tab.
                In the work area, Fit Type column, select a numerical method for each output
                    response.
                By default, FAST is selected.
 - Optional: In the Settings tab, change settings as needed.
                Click Apply.
                A run matrix is generated using the numerical method you selected.
