Model Types
Learn about the different type of models available in HyperStudy.
Beta Preprocessor Model
Use the Beta Preprocessor model to create a parametric connection to a B Preprocessor database enabling you to generate solver input files.
Version
N/A
File Extension
.ansa
Multi-Execute Support
Yes
Response Definition Support
No
Registration Steps
Register a solver script that points to an ansa startup.
For example, ...BETA\ansa_v17.1.2\ansa64.bat.
Usability Characteristics
The FE output path in a .ansa file should be relative. If it is not, you will receive a warning when importing input variables.
Once the optimization task is defined, save the current model as <modelName>.ansa. Verify the dvfile name follows a naming convention of <modelName>_dvfile.txt and is in the same directory as the .ansa file. For example, feasolver_beam.ansa, feasolver_beam_dvfile.txt.
Existing Data Model
Use the model to leverage historical data residing in a directory. Each result file is automatically distributed to its respective run folder. The allocation of files is based natural sorting.
Version
2023 or above
File Extension
N/A
N/A
N/A
Registration Steps
N/A
The number of runs is fixed and equal to the number of result files selected. Hence, this model type is better suited for DOE cases.
FEKO Model
Use the FEKO model to connect to a Feko project, which enables you to automatically detect input variables and run high frequency electromagnetic simulations.
Version
2017 or above
File Extension
.cfx
Yes
No
Registration Steps
Register a solver script that points to runfeko.exe.
Output responses from Feko are written to the hst_output.hstp file by a custom .lua script. If no .lua script is present, Feko will generate a nominal script which performs a trivial calculation. This nominal script must be modified to request the specific output response of interest from Feko.
Flux Model
Use the Flux model to connect to any Flux 2D and 3D project, which enables you to automatically detect input variables and run low frequency electromagnetic simulations.
Version
Flux 12.1 or above
File Extensions
.F2G
.F2HST
Yes
Yes
Registration Steps
Register a solver script that points to flux.exe. For more information, refer to Register Solver Scripts.
  • Some Flux outputs (such as curve value extractions) require a post-processing python file to be executed after each simulation. If a python command file is required, it should be specified in the .F2G or .F2HST file. Drag and drop the .F2G or .F2HST file into HyperStudy to connect the model and identify the inputs and the outputs. Once a connection is established, HyperStudy can automatically run as many Flux simulations as requested by the method (DOE, Optimization).
  • For information on how to expose Flux model parameters and outputs to HyperStudy by means of a .F2G or .F2HST coupling file, refer to the Flux help and HyperStudy dedicated tutorial.
FluxMotor Model
Use the FluxMotor model to connect to a FluxMotor model.
Version
2018.1
File Extension
.fm2hst
Yes
Yes
Registration Steps
Register a solver script that points to FluxMotor_Install_dir/Scripts/win/FluxMotors.exe.
Refer to the FluxMotor help for more information on how to expose FluxMotor model parameters to HyperStudy.
FMI Model
Use the FMI model to leverage Functional Mock-up Interface models to perform co-simulations.
Version
2023.1 or above
File Extension
.fmu
N/A
Yes
Registration Steps
N/A
Only continuous input variables are supported.
Responses are in vector form. Hence, scalar responses are to be created by users.
HyperMesh Model
Use the HyperMesh model to directly access the HyperMesh database of the model, which enables you to perform easy design parameterization of solver input files.
Version
Current HyperStudy installation
File Extension
.hm
Yes
No
Registration Steps
HyperMesh is automatically registered in HyperStudy.
  • Input variables are limited to solver interface specific presets and general parameter entities.
  • Can be used with any solver script.
HyperStudy Fit Model
Use the HyperStudy Fit model to import the python based report created by a Fit approach from another HyperStudy session.
Version
N/A
File Extension
.pyfit
Yes
Yes
Registration Steps
N/A
HyperView Model
Use the HyperView model to connect to a HyperView session file, which enables you to automatically extract hotspots.
Version
2021.1 or above
File Extension
*.mvw
Yes
Yes
Registration Steps
N/A
  • Used as a subsequent step after a numerical analysis.
  • Adding solver argument, -image, generates screenshots of hotspot contours.
Inspire Model
Used to leverage Inspire models.
Version
2026 or above
File Extensions
.stmod
Yes
Yes (in Analysis mode only)
Registration Steps
Register a solver script that points to ExecWinEnvInsp.exe
  • Only continuous input variables are supported.
  • Supports both CAD-only and Analysis modes. Analysis mode requires at least one simulation saved along with results. In CAD mode, since there is no response, the Ignore Dependencies model condition may be needed.
Inspire Studio Model
Use an Inspire Studio model to automatically modify geometric entities.
Version
2021 or above
File Extensions
*.ist2hst
Yes
No
Registration Steps
Register a connection script, that points to hw_hst_cmd_istudio_write.bat by setting the environment variable, HW_HST_CMD_ISTUDIO_WRITE.
  • Windows support only.
  • Both resource (*.ist2hst) and Inspire Studio session (*.iStudio) files are expected to be in the same directory.
Internal Math Model
Use the Internal Math model to create input variables that are contained entirely within HyperStudy and do not map to any external applications.
Version
N/A
File Extension
N/A
Yes
No
Registration Steps
N/A
  • Used to link variables between models.
  • Used for variables used directly in response expressions.
Knowledge Studio Model
Use a Knowledge Studio model to import the predictive model from a Knowledge Studio session.
Version
2020.1 or above
File Extensions
.kdm
Yes
Yes
Registration Steps
Register a solver script that points to <...>/Altair Knowledge Works/KS Workstation 2020.1.0/HyperStudy/runKS.bat for Windows and <...>/Altair Knowledge Works/KS Workstation 2020.1.0/HyperStudy/runKS.sh for Linux.
  • Verify that the path to the Python executable is valid in the Knowledge Studio installation configuration file, KS Workstation 2020.1.0/HyperStudy/runKS.cfg.
Lookup Model
Use the Lookup model to extract values from a file with known input/output pairs.
Version
N/A
File Extension
.csv
Yes
Yes
Registration Steps
N/A
  • The .csv file must be structured so that all of the first N columns are imported as input variables, and all remaining columns are imported as output responses.
  • Evaluation of the model with input variables that have no matching row will result in an execution failure.
MotionView Model
Use the MotionView model to directly access the HyperView database of the model, which enables you to perform easy design parameterization of solver input files.
Version
File Extension
.mdl
Yes
No
Registration Steps
MotionView is automatically registered in HyperStudy.
Can be used with any solver script or the have MotionView run the solver defined inside itself.
Operator Model
Use the Operator model to execute a process but not have an associated write operation.
Version
N/A
File Extension
N/A
Yes
No
Registration Steps
N/A
Frequently used in conjunction with linked model resources in order to define the steps of a process flow. A process can be defined as a sequence of HyperStudy models, including Operators, rather than a single model with a single detailed and non-reusable solver script.
OptiStruct Model
Use the OptiStruct model to directly use parametric *.fem files without a pre-processor.
Version
2021.2 or above
File Extension
*.fem
Yes
Yes
Registration Steps
N/A
  • Symbolic substitutions are automatically detected as input variables. If no symbolic substitution is defined, thickness values in each PSHELL card are read as variables by default.
  • Volume, Mass, and Maximum Displacement per subcase are default outputs.
  • Use DRESP for user-defined responses.
  • DESVARs are supported. However, they require an optimization setup with at least one objective. To avoid a full optimization run, the DESMAX parameter must be set to 0. This provides the results of first iteration only.
  • OptiStruct internally updates the inputs via reading current values of hst_input.hstp file in each run directory. Hence, .fem files in run directories do not reflect the updated input values.
Parameterized File Model
A Parameterized File model is a general ASCII text file, which has search and replace substitution for input variables.
Version
N/A
File Extension
.tpl
Yes
No
Registration Steps
N/A
  • A Templex language syntax is used inside of the parameterized file.
  • The formatting in the parameterized file is independent of the internal storage.
PhysicsAI Model
Use the PhysicsAI model to pull directly from the file's geometry without the need for parameterization.
Version
2023.1 or above
File Extension
.psmdl or .p
N/A
N/A
Registration Steps
N/A
Generates H3D files at the end of each process.
Requires an input deck file as solver input argument.
Radioss Model
Use the Radioss model to directly use parametric Runname_0000.rad starter file without a pre-processor.
Version
2021.2 or above
File Extension
*_0000.rad
Yes
No
Registration Steps
N/A
  • Entities in /PARAMETER cards are automatically detected as input variables.
  • If engine file, Runname_0001.rad, is exported separately, they are automatically copied to run folders if they are in the same directory with the starter file.
  • Include files need to be manually selected and copied via Model Resources tool.
  • RADIOSS internally updates the inputs via reading current values of hst_input.hstp file in each run directory. Hence, .rad files in run directories do not reflect the updated input values.
SimLab Model
Use the SimLab model to parametrically drive SimLab macros, which can be used to automatically mesh and solve FEA problems.
Version
2019.1 minimum
File Extension
.py, .pyc
.js (legacy format)
Yes
Yes
Registration Steps
Register a solver script that points to bin/<platform>/SimLab.bat.
  • The HyperStudy directory (.hstudy) and the SimLab project directory cannot be the same.
Spice Model
Used to leverage LTspice, NGSpice and HyperSpice models.
Version
HyperSpice 2025.1
File Extensions
.cir/net
Yes
Yes
Registration Steps
Register a solver script that points to the LTspice/NGSpice/HyperSpice executable.
  • Data Sources are automatically extracted and scalar responses are created by users.
  • Include files are supported.
  • Parameters with expression definition are ignored.
Spreadsheet Model
Use the Spreadsheet model to perform calculations.
Version
Microsoft Office
File Extension
  • .xls
  • .xlsx
  • .xlsm
No
Yes
Registration Steps
N/A
  • Input variable and output response cells are identified by the user.
  • When creating a Spreadsheet model an input variable's value and label can be formatted in two consecutive rows or two consecutive columns. Input variable labels should only contain English characters, or a combination of English characters and numbers. If you do not create a label for a variable, HyperStudy will assign one by default.
  • On a Windows operating system, Spreadsheet models will be brought to the front. HyperStudy will prevent you from accessing any spreadsheets that you had opened prior to or after (by double-clicking) starting your current HyperStudy session.
    To access an Excel spreadsheet while running a study with Spreadsheet models, you must explicitly start a new session of Excel.
  • Windows platform only
  • Support for VB macros
Twin Activate Model
Use the Twin Activate model to directly use parametric .scm files.
Version
2025.1 or above
File Extension
.scm
Yes
Yes
Registration Steps
Register a solver script that points to “<TwinActivate_Install_Dir>/Activate_batch.bat"
Outputs are read as Data Sources. Hence, scalar responses are created by users.
Windows is the only supported platform.
Workbench Model
Use the Workbench model to connect to an ANSYS workbench project.
Version
17.1
File Extension
.wbpj
No
Yes
Registration Steps
Register a solver script that points to runwb.exe.
  • Input variables are automatically detected from Workbench input parameters.
  • Output responses are automatically detected from Workbench direct outputs.
