Evaluation Parameters
Modify the run environment settings for the Evaluation tasks.
- From the Evaluation step, click the Evaluation Parameters tab.
                In the Value column, modify settings accordingly.
                Note: Review the Effectuation column to determine the scope at which each setting takes effect.
