Channel
Analysis > Channel > Create Profile
This option is used to create the specified profiles for the channel. It is represented by a symmetrical 2D cross section of a channel with the Dimensions L1, H1 and A1. With origin as a midpoint of the dimension L1, the symmetric profile is created in the global YZ plane for the specified dimensions.
Figure 1. Create Channel
