Induction machines – Motor Factory – Test environment
The computation of power balance for IMSQ in “accurate mode” is not well balanced.
In the test “working point – sine wave – motor – U, f, N”, while computing the power balance with the accurate mode (i.e., with the transient application) the results are not well balanced. Indeed, the difference between the electrical power and the power on the shaft is not exactly equal to the total amount of losses.
The computation of the efficiency map (U, I) with mechanical losses can fail.
This issue raises a null-pointer exception (ref.: FXM-16157).
The flux density is not displayed in accurate mode computation.
While computing a working point (U, f, N) for an induction machine with a skewed squirrel cage and outer rotor the flux density inside the airgap is not displayed. (ref.: FXM-16154).
Error when exporting and solving a project in Flux Skew – Transient application.
This issue occurs when the user input “Represented coil conductors” is set to All phases (ref.: FXM-15877).
IMSQ - Scalar Maps or Efficiency map (U,f) tests fails with hairpin winding technology
Sometimes, the tests Scalar Maps and Efficiency map (U,f) are not correctly solved with a hairpin winding configuration, like for the Motor M1 of the reference catalog (ref.: FXM-15843).
Power balance of No-load working point
Sometimes, computation of the no-load working point (slip=0.1%) leads to a NaN (Not a Number) result. The computed amount of iron losses is not consistent with the power balance (ref.: FXM-12600).
Torque slip curve
Test results are not continuously consistent over a torque slip curve. This occurs with the test Performance mapping T(Slip) - induction machines with a skewed squirrel cage. When the user targets a working point as an added value to be computed
with the whole Torque-slip curve, sometimes this additional working point doesn't belong to the curve.
(ref.: FXM-12599).
